chemoman
Oct 10, 2014Explorer
carringb wrote:
P1000 is the "not ready" code. It's to keep folks from clearing codes before heading in for smog testing. It only means since your last re-flash, the trucks hasn't completed all of the necessary tests to pass smog. Since you did a delete, that code may never go away unless you restored everything.
SO, the code will not affect anything? It wasn't flashing on the check engine light. I only noticed through the tuner while checking for why the truck was making that noise?
