TheGreatWaz00ExplorerMay 30, 2015Drain Hot Water??Are you supposed to drain the hot water tank between trips? We ill average 2-4 weeks between trips?
midnightsadieExplorer IIMay 30, 2015I drain my system every time, all you gotta do is open the drain valve. I like fresh water.
Related ContentDraining water linesWhen do you drain your lines and hot water heater?Hot water-hot rod issue.Hot waterUnderstanding hot water
