- kellemExplorerPerhaps a minority here as I pull both valves " black and gray " at the same time.
What I've found is a vacuum effect is created at the Y connection and black tank has a much better disposal rate.
I do however spray out the slinky. - Taxman2436ExplorerWell, that makes sense. I do have the black tank flush and that will take care of it. Thanks for that!
- LwiddisNavigatorDon’t hesitate to fill both tanks just before dumping...black then grey...if water is available.
- CA_TravelerExplorer IIIInstall a tank flusher in the black tank or use a cleaning wand in the toilet.
The reason we drain the black tank first is to clear out the drain hose with the grey tank water, nothing to do with flushing the tanks.
