Ozark Farmer wrote:
Has anyone thought about or made a modification to put in a drip pot diesel stove into their TT for cold weather camping? I had a small one on a fishing boat that was entirely gravity fed from a gal tank and it heated the whole cabin and didnt need electricity to do it.
This would require a small stack and I suspect a lot of people wouldnt want to get any soot on their shiny rigs but for boondocking it seems like a good fit.
Just looking at some options/bouncing some ideas.
:E:E
Seems to me this idea is an accident just waiting to happen.
Cheap in this case can turn on you in a bad way in a hurry.
There IS a reason as to why you don't see these in use in homes, autos, RVs boats and so on.
Regulating the oil "drip" is virtually impossible.
Oil changes viscosity quite a lot over a very short temperature.
To keep it from over firing you would have to constantly monitor and adjust the drip rate.
Why be so darn CHEAP :h
If you can not afford to spend a few $$ on running a proper RV propane furnace then you should not and have no business living or using a RV in the winter, period.
Your life (and others) along with your RV is certainly not worth risking a catastrophe :M
