Artum Snowbird wrote:
I would consider a few things. Your rig is likely about 2200 pounds on each front leg. You would likely want to use plywood, two layers or even three, sandwiched together. Solid wood can split easily, but plywood will not.
You want to be on level ground, and be sure your front supports are wide enough the rear wheels will not contact them as you pull straight out.
I would likely build front supports three layers thick, two feet long by six inches wide, and rear supports three layers thick and one foot by one foot.
Yah, Ditto that on splitting and rear tires driving over the front... it's a close call on the front ones to keep the rear tires from driving/cracking wood over it...
I need height more than stability, but in soft ground need the wider pads.. I got some yellow jack pads, but little a little too small. so put them on the woods ones..
Sigh, a learning curve indeed, heheheh, fun..
