Bionic Man wrote:
Looks like your questions have been answered.
I don't take my DRW out often in the snow. When I have, I put it in 4x4 and haven't had issue.
Question from me. For those that have mentioned getting a rock stuck between the tires, how do you get it out? Do you have to remove the outer tire?
Big problem with rock between tires is when it cuts the sidewall. Got one out once when tire blew due to cut sidewall. It was easy to see something had been rubbing between wheels in aftermath. Another time got a chunk of Lava Rock stuck in between the wheels up in Idaho and tore up one of the sidewalls bad enough I ended up changing the tire. tire never failed though.
