rvshrinker's avatar
rvshrinker
Explorer III
Jan 30, 2017
DRW in snow, off road, etc.
I'm closing in on a RAM 3500 DRW but have some questions about off road and snow travel.
If I don't have the TC on top, I see these things don't do well in snow. Some people have talked about airing down, about throwing weight in the back, about removing the outside wheels, or some combination of all of the above. What is SOP for improving snow handling when the bed is empty? Snow tires? I don't think I'd do this often as I have an old toyota RAV4 with 4x4 and snow tires which does just great and I plan to keep that vehicle..
With the TC on, I'm sure it will handle better in snow. To go to the ski resort sometimes M&S tires or chains are required. do I need 4 or 6 snow tires for this application?
Finally, off road, with or without the TC in place: I'm not rock-climbing or anything, but want to be secure crossing low streams and deep holes or maybe even some light sand. Is the DRW ok for this? I see some folks air down for sand, that's a pretty easy fix because it would be a rare occasion that I would do that.
thanks
  • When you rhubarb it duallies have waaaay better stability sliding down the embankment.
  • I live in Indiana and have owned duly's for years now, both gas and diesel. Not a problem for me at all, even with stock tires. However when snow is on the road I drop into 4x4, never a problem. But still, regardless of what you are driving, hit a patch of ice, and even 18 tires on the ground will end up in the ditch! In snow, common sense, slower speed, and ... common sense. It's about getting there safe, NOT fast!
  • I don't know about sand, but as far as I'm concerned, maintaing directional control is of primary importance in snow. Having enough traction to go x mph means nothing if you can't keep it between the ditches.
  • I had an 05 CTD dually with a big S&S TC. I took it places I really shouldn't have. The only problem I had was getting a baseball sized rock lodged in between the duals while crossing the McGruder Corridor.
    With the stock General tires it was completely worthless in snow without 4x4 kicked in. Went to Les Schwab and put on 6 Toyo M 55 with center sipe. Wow, what a difference. Towed an enclosed snowmobile trailer up the mountains in 4x2, no weight in the back, no problem.
