rhagfo
Jun 13, 2013Explorer III
mowermech wrote:Me Again wrote:
I noticed that he did not have equalizer bars on the hitch, which might have prevented this from happening!!! Chris
If the wind was THAT strong (and it obviously was!), I very much doubt that a WD hitch would have made a bit of difference!
The winds between Big Timber and Livingston, MT, on I90 often blow 80,000 lb semis over. An RV doesn't stand a chance, even if it has the most expensive high-tech hitch available!
Long light TT!
Just looking at the video the winds were very gusty, a 5er of the same size might likely survived. That would be for two reasons while a bit taller, also much heaver, that TT could be as much as 4,000# lighter than a 5er of the same length.
5er hitch has a limited side tilt before it would also need to take the truck also. Not saying that it can't happen, but in this case not likely.
44,025 PostsLatest Activity: Feb 18, 2025
