mbloof wrote:
Lantley wrote:
There is always friction between road and tire.
One of the reason cars cannot stop on ice is there is no friction between tire and ice.
Sure the brake pads stop the wheel but on ice the wheel does not stop the vehicle.
Eliminate the ice and the vehicle is able to stop.
Forgetting for the moment that it is the friction between pads+rotor that ought to be slowing/stopping rather then the tires themselves here's what I had exception with:
"My dually also has more braking power, it certainly stops my trailer much faster the my SRW trucks. Again this is determined from the drivers seat not from the text book."
I'm simply pointing out that for 1T trucks the SRW and DRW have the same pads and rotors IE: SAME BREAKS.
Any implied or imagined extra stopping "power" is NOT from the breaks.
- Mark0.
Your catching on. I never said it was due to the brakes. As you claim the brakes are the same.
It's do to the fact it is a DRW truck that has 2 extra wheels that gives it additional tire surface that contacts the ground!
