Mickeyfan0805 wrote:
dodge guy wrote:
I agree completely. The only difference is the one with the higher GVWR will have better brakes tires and suspension. And even that sometimes can be questionable.
Absolutely - which simply underlines the point. My greatest fear of the 'Go by GVWR' mantra is that someone new to trailering would go out and buy a 5,000 pound trailer with a 6,000 GVWR over a 5,000 pound trailer with a 7,500 pound GVWR based purely on the advice that they should stay under 7,000 pounds GVWR. Both would be equally safe in regard to weight, but the first will quite possibly end up dangerously overloaded on the trailer side while the second will travel with capacity to spare.
I would disagree with that. Both trailers are more then likely to have the same axles under them. The second trailer just assumes you have more tongue weight then the first trailer, hence giving you a higher GVWR. Now if they have different axles under them, then you may have a point. But they only make axles in a few ratings, the difference in axle ratings are in thousands of pounds, not hundreds.
