Raife's avatar
Raife
Dry vs Gross weight
First some context:
Good afternoon. I have read many posts regarding towing and am looking for some additional help. Sorry for the dissertation…
First – context:
Vehicle and weights:
- 2015 Durango, Citadel, V8 Hemi, factory installed tow package, technology group (not sure this matters)
- Curb Weight – 5770 pounds (measured on certified scales, full tank, minus my weight)
- Family weight – 610 pounds (me, wife, 3 kids, and dog)
“Remaining“ cargo weight – GVWR of 7,100 minus 5770 curb weight minus 610 family equals 720 pounds (which I imagine most will be taken up by tongue weight)
If I take the Gross Combined Weight Rating (GCWR) of 13,100 pounds and subtract out the curb weight of the Durango (5770lbs), the family weight (610lbs), and the tongue weight (max 720lbs for calculation sake), I end up at 6,000 remaining pounds for the trailer.
So I started down the path of a Jayco 264BH, but received a fair amount of feedback that the tongue to tail length of 29' was too much for the Durango wheelbase.
So I am now looking at a tongue to tail in the 25' range (sail range of 22').
However, I am finding a lot of trailers that have dry weights in the low to mid 4Klbs, but then CCC weights of 2-3Klbs - which puts me over the 6,000lbs limit I calculated.
So - given I will not be traveling with full tanks (only what is potentially used during travel from campsite to campsite), how important is the trailer GVW (UVW + CCC) vs a different number (say UVW + 1,500lbs of our stuff in the trailer, even if the CCC is 2,500lbs)
Regardless of what I get, I will get getting a WDH with 4-point or dual-cam sway control.
Any help is greatly appreciated.
Thank you in advance!
  • jdc1's avatar
    jdc1
    Explorer II
    You might be looking at a 4,500 pound trailer for the best results.
  • Part of the equation is up to you. You do not have to load to maximum weight. Water, fuel, extra batteries, etc. all add pounds. Little things add up. Mot of us take more "Stuff" than we really need.
  • “So - given I will not be traveling with full tanks (only what is potentially used during travel from campsite to campsite”
    You are assuming the campground water is working when you arrive. What if it isn’t? You are willing to pass up the beautiful dry campsite you spotted from the road? No water in your tanks. Lots of those CGs out West. Running at or close to max for your tow vehicle and/or the trailer isn’t fun.
    What if you don’t like the taste or smell of the campground water? Tuff, you must fill up.
