SoundGuy
Nov 03, 2015Explorer
Campfire Time wrote:
While I agree that people can load different amounts of weight, by using the GVWR as a guide you will never be wrong on sizing your tow vehicle.
Of course you can! :( Rigs spec'd with so much CCC that very few would actually use could convince one it's necessary to go up a category in tow vehicle, say 3/4 ton instead of 1/2 ton, when in fact it wouldn't be required at all with a reasonable cargo load. If a trailer's GVW, loaded and ready to camp, is comfortably within it's GVWR then fine, use the GVWR as a worse case scenario, but if GVW with a practical load is several thousand pounds below GVWR then it would be a horrendous mistake to use GVWR as a guide in determining which tow vehicle category would be necessary to safely tow that particular trailer. Good grief, no wonder so many newbies find the subject safe towing so confusing! :S
