wildtoad
Jun 30, 2016Explorer II
Was the water really really hot when it worked? Could be a bad thermostat. If I remember correctly there is a thermostat and an Emergency Cut Off (ECO) which is a fail safe should the regular thermostat fail to turn off the burner. Could be the switch turned on the wh and the ECO turned it off. It will not turn back on by itself if the thermostat is bad.
