nephi007's avatar
nephi007
DSI Atwood propane only water heater
Hello. We fired up the Atwood this morning via a DSI switch in travel trailer. 20 minutes later hot water aplenty from the 6 gallon tank. Left switch on and left for awhile. Returned and no hot water or warm water it was cold. So whatever recycles the hot water heater to turn back on when I assume it goes below a certain temp did not happen. Or is there another explanation?. There is plenty of propane. This is a new 2016 model and if I need to take it back to dealer if I will, Advise please.
  • Was the water really really hot when it worked? Could be a bad thermostat. If I remember correctly there is a thermostat and an Emergency Cut Off (ECO) which is a fail safe should the regular thermostat fail to turn off the burner. Could be the switch turned on the wh and the ECO turned it off. It will not turn back on by itself if the thermostat is bad.
