stevenal
Feb 21, 2017Nomad II
dual alternators
I see Superduties have dual alternators listed as an option. Anyone have this setup? Do you like it? And how are the loads separated? Thanks.
Kayteg1 wrote:ggardne2 wrote:
Electric cabin heater is standard on new Super Duty Diesel's in cold climates. It is simply a supplemental heater to help with cabin warm-up in cold climate since Diesel engines have such a long warm-up time when the vehicle is operated at light load.
In terms of two batteries, that is to provide enough current to crank the Diesel engine in cold climates while at the same time maintaining current for your glow plug system.
Diesels do produce very little heat at idle to start with.
Cold-climate vehicles do come with Webasto heaters as on average commute in cold weather diesel never reaches operating temp.
For some reason Webasto is not an option on US models.
Years ago I ended up in No. Dakota in winter with intention to sleep in the cabin.
The cabin was well warmed up due to hauling, but right after midnight I woke up due to cold. The hot engine at idle cooled down and dash temp gauge went down to 0.
I pushed gas pedal to give it more heat, but it was not much use.
Electric heater not only keeps cabin at comfort level, but also adds load to the engine- keeping it warmer as well.
But dual alternators are installed without electric heaters as well.
Might be good for those who install 4000W stereo in their Superduties.
jimh425 wrote:
I've read more about this Rapid Heat option. Based on what I've read over at Ford-trucks.com, it's kind of interesting that it comes on automatically, and there aren't any switches to flip.
skyhammer wrote:
My Ford has dual alternators, 1-200 and 1 150 amp.
At start up in the Winter, I am drawing well over 200 amps.The supplemental heater is 1200 watts(120 amps), glow plugs, two seat heaters, air compressor, head lights, plus the other 25 lights or more if trailer and camper are hooked up, and the draw that all the 12 volt and 120 volt outlets have, stereo and other things I forgot.
