stevenal
Feb 21, 2017Nomad III
dual alternators
I see Superduties have dual alternators listed as an option. Anyone have this setup? Do you like it? And how are the loads separated? Thanks.
ggardne2 wrote:
Electric cabin heater is standard on new Super Duty Diesel's in cold climates. It is simply a supplemental heater to help with cabin warm-up in cold climate since Diesel engines have such a long warm-up time when the vehicle is operated at light load.
travelnutz wrote:
I have dual alternators on my Duramax and ordered the truck with that option. Dual 145 amp. .... Works fabulously! Very short recharging time even when recharging with the diesel engine idling. Will have the same exact setup if we were to buy a new Duramax truck too!
joeshmoe wrote:
Ever try to start your truck on one battery? I don't recommend it.
jimh425 wrote:
As far as two versus one goes, redundancy is usually a good thing and probably why Super Duty diesels have two batteries.
In terms of two batteries, that is to provide enough current to crank the Diesel engine in cold climates while at the same time maintaining current for your glow plug system.
deltabravo wrote:54suds wrote:
Two alternators can also serve as a jerry-rigged replacement for larger alternators by combining two in series to reach the same level of power output, which is particularly helpful in improvised repair situations.
Your post is confusing.
They aren't hooked in series.
