joexsmoot's avatar
joexsmoot
Dual Alternators for A/C Removal, newbie
Good morning everyone! I'm joe, new to the forum. To give a super quick backstory, I bought a 87 Minnie Winnie for $500 about a year ago, it was stripped and a leaky mess. 1 year later, me and my girlfriend updated the whole thing. Took it on one or two trips, engine smoked a lot.
Fast forward, i'm pulling the 460 8 cyl 7.5l EFI out, and replacing with one with lower mileage. The A/C did not work, and it is the old style refrigerant which is hard to come by and expensive, especially if I don't even know why it didn't work. However our 110v roof top unit works amazingly, and i'd like to capitalize on that.
Is it possible and realistic to remove the A/C compressor and install an additional alternator in it's place? I would run the 2nd alternator's lead (with external voltage regulator) directly to a fuse block which connects to my house battery bank and the DC to AC inverter
Ideally, it'd go something like this:
This would be something that would benefit me by: saving me to upgrade the A/C system to the current refrigerant, be a lot more cost effective (alternator is $100 autozone, wiring and fuse roughly $80, no frills regulator $30-50) VS starting off with a $350 compressor (autozone) let alone whatever else needs to be replaced (sensors, tubing, condenser, cooler, blower assembly are all 35+ years old, plus refrigerant etc). When the DC to AC inverter isn't drawing more then what the 2nd alternator is supplying it acts as a charging unit for my batteries, which saves me $100-300 just for that unit alone.
I don't use the unit dry very often, it's usually hooked up to some form of campsite power. I figure this method would be best for my short and sporadic uses. It benefits me cost wise, I don't ever plan on selling, and I don't foresee a power issue seeing the house batteries / appliances are a completely isolated charging system.
What do you all think?? Let me know, feel free to give me any ideas or issues you forsee in the future!
THANKS EVERYONE!!!
