Just for grins, and I'm sure it will work out in your head,...I have a dual pane door conversion in the university sticky. It worked out really well using high end acrylic on the inside and glass on the outside..the conversion was a game changer for a door..flat out the builder doors are built wrong and should just come this way. My beef was the clear pane was on the bottom... you expect to see though the clear panel though the truck and TC that was at the floor?, It does not happen especially when pulling a trailer.. what does it matter?...and it had privacy glass on the top.. WHY?. Wrap your head around this..it is an 11.5. I can't see trough the door while driving...but someone can walk up and see right into the camper at ground level?..It just did not make sense. So I put the privacy glass at the floor and the clear at the top so I could see out at the door when I am inside and look out or down...does that make better sense? Go look it up.
