tony066's avatar
tony066
Dual rear tire valves
I just bought my first dual rear tire truck and am wondering about the inner tire's inflation. I can't get my hand into the small opening in the wheel to reach the valve stem. Is there a tool to reach the stem and remove the cap? I am also looking at a valve extension but am concerned that the centrifugal force of the spinning wheel will exert undo force on the extension and possibly cause a problem with the valve stem. What is the usual solution to this problem? Thanks for any help on this.
  • Cat's eye tire pressure systemThese have been used on semi's for years and they will work on systems from 60-125#. Depending on your tire pressure this might be an option. Keeps the two tires balanced and a quick glance your good to go.
  • After having problems with extenders I removed them. I reach the inner valve stem cap with a rubber hose that the cap just fits into and twist the hose - easy off and easy on.
  • My truck came with valve caps that allowed checking the air pressure without removing them. These are metal but years ago I had some that were plastic.
  • Community Alumni's avatar
    Community Alumni
    Not applicable
    Here you go:
    http://www.campingworld.com/shopping/item/dual-tire-inflators-hub-mount-stainless-steel-4-hose-kit-for-16-19-5-wheels/5786
