GoPackGo's avatar
GoPackGo
Dually Alignment
Hi everybody - I've never owned a dually before and I want to get a wheel alignment done. Is the process the same as any other 4 wheel vehicle ? Do they align all 4 corners or do they align just the fronts ?
I have a 2013 F350 if it matters.
Thank You,
Tim
  • Thanks for the reply. You confirmed what I kind of wondered - there's nothing to align on the rears.
    I did buy it new (May - 2013) but I now have 18,000 miles on it and it seems to want to pull off to the side a little. And my experience has been that vehicles don't come perfectly aligned from the factory.
    Tim
  • A good place will check the rears but there isn't anything to adjust on the rear so unless they find a problem they don't do anything. Front is the usual caster, camber, toe, center the steering wheel. Why do you want an alignment on such a new vehicle?
    Brian
