ksss wrote:
If you need the capacity of a DRW to pull your trailer than absolutely get one. If you don't need the extra capacity of a DRW then why get one? Two more tires to buy, and being a gas I think it will impact MPG more than the same combo would in a diesel. I have both 3500 DRW and 3500 SRW and I prefer the SRW for everyday driving. The DRW shines when it is hooked to a heavy trailer. However the capacities of todays SRW pickups with improved suspension, and tire/axle combos have in my view closed the gap considerably.
Definitely closing the gap, but the 3500 DRW truck has it's limitations just like a 3500 SRW, just like a 2500, just like a 1500....they all work well when used in their capacities and applications.
As far as closing the gap, There's still a pretty good gap between GVWR's, and even a wider gap when it comes to GCWR, between a 3500 SRW and the Dually.
By all means, do not purchase a Dually if you don't need one, but IF you DO need one, best not cutting corners on a TV.
