Powerdude wrote:
donn0128 wrote:
This will still not alter the GVWR sticker on your drivers door post. If your going to go this route, I would suggest you find a donor dually to take the bed, rear axle assembly from. Remember duallies also have different studs, longer to accompdate the dual wheels. Of course, once you have the bed painted to match the cab, and the donor parts your total cost would likely exceed the cost to trade plus cash for a real dually
Find a wrecked dually of your year, take the axle, and the door sticker. Replace your door sticker with the one from the dually.
Problem solved.
His sticker is already 3500. Never seen anything stating a rig bring a "Dually".
EDIT You probably meant the weight rating sticker!
