If you've got one of a pair of dually tires sitting on thin air, then obviously the other tire is carrying ALL the weight.
So do you know how much weight each wheel position is carrying? And do you know how much weight a single wheel is rated to carry, at the air pressure you have in it?
If you can answer those two questions, then the answer to your question should be obvious.
