JRscooby
Jul 01, 2019Explorer II
GTO66 wrote:
No its gravel between the tires. Happens mostly without the TC. When I have to park in the over flow at the boat ramp, Plenty of loose gravel have spoke to others with DRW who have said the same.
You might be driving on some size of bedding rock. But gravel is normally smaller than inch and half. And that size rock, you should not sink deep enough to wedge between the tires. If the sidewalls are that close together you might have a issue of heat transferring tire to tire...
