Moving up to a dually and don't really have any experience with them so I have a couple questions. 1. I level by driving onto blocking, for the rear tires do I need to put blocks under both duals o...
Not a stupid questions at all . There are no absolutes to your questions. Here is my experience. 1 block just one rear wheel unless it is long term. 2 no valve extensions , I use a dually air Chuck 3 same air pressure in all rear tires 4 I have gone one size up on tires , as long as you have half inch or more at the bulge under full load . Tires should not touch.
