djcjc
Aug 06, 2014Explorer
Dually rear tire wear
I have 27,000 miles on Ram dually and the rear tires are worn down to less than half tread left fronts are fine is this normal with dually's. I always keep tire inflated to the reccomended pressure.
P Kennedy wrote:
Cummins 12v98 I think you will find your Ram has gear type power transferring limited slip differential. The torque generating from the Cummins I6 is a lot lower rpm than the V8 diesels therefore it will wear rear tires quicker especially if inflated to the max. This of course will be amplified by more aggressive driving styles. Just saying?
