djcjc
Aug 06, 2014Explorer
Dually rear tire wear
I have 27,000 miles on Ram dually and the rear tires are worn down to less than half tread left fronts are fine is this normal with dually's. I always keep tire inflated to the reccomended pressure.
larry barnhart wrote:larry barnhart wrote:
We tow with 80 lbs for the rear
and lower to 50lbs for solo winter driving in Az.
chevman
We bought new Michelins tires in 2011 . I used a pop cycle stick and a very sharp pencil to make a mark for the tire depth . yesterday I measured the depth using that stick. 5 tires showed the pencil mark was just above the rubber and one tire was the same as new. Hard to believe but true and the same as last summer when I checked. 17000 miles and 2 rotations only because it is free. I will rotate soon. After I rotate and come home I torque the lugs because nobody has done a torque correct ever for me. Michelin tires are the highway tread LTX M/S 2. No cracking but if or when it happens it will be a no more Michelin tire purchase for us.
chevman
