djcjc
Aug 06, 2014Explorer
Dually rear tire wear
I have 27,000 miles on Ram dually and the rear tires are worn down to less than half tread left fronts are fine is this normal with dually's. I always keep tire inflated to the reccomended pressure.
larry barnhart wrote:
Can a dodge truck get the tires rotated with out taking the tires off to keep the wheel in the same spot. Once the fords could not so it was a high cost to do the job and balance the tires . If this was the way for me I would not rotate either.
chevman
