^^^ What Ron Said! FYI no duallie needs more that 65 in the rear wheels. If the fronts are 17" tires and have max load at 80 psi, I would running them at 80 PSI 24/7/365. With my SRW I leave the 18" fronts at just over 60 PSI and vary the rears for empty at 42-44 psi to 65-80 depending on load. That is 80 with the 5th wheel and around 65 with the bumper pull. Or 80 PSI with a 3K load of wall blocks in the truck bed.
Here is a 235/80R17E inflation chart for both single(Front) and dual(rear).
https://tirepressure.com/lt235-80r17-tire-pressure
