AISURFFISH
Apr 05, 2015Explorer
1971amerigo wrote:
I don't believe a crossfire system will let you deflate your tires.
They have a check valve to prevent accidental deflation.
They will air down if you special order your hoses with the additional valve before the check valve/gauge.
I have the set with the additional T in the hose so that I can air down to go on the beach the air will leave through this valve for each tire. this setup is also for people who have automatic tire pressure gauge is built into their truck system you would put your vehicles gauge here instead of at the valve stem..
I would also recommend having your valve stems changed when having these installed just to make sure you are getting a nice clean fresh seal to start off the job. when I did mine unfortunately I had a leak on one of the inner tires and it was because of the valve stem. once I replaced that Valve Stem everything worked fine.
