Yep, long line behind, dump and go. If there is noone then get out the hose and shove it down the toilet till half full and dump again. Another quick rinse if you don't have a sani wash is to lift up the sewer hose and put water in it for awhile and then lower it down to the dump hole. If there is a big line I dump and pull out and stop at a wide spot and add a couple gallons or until I get tired of hold the flush valve on the toilet so it will slosh around on the way home. It will get the toilet paper off the sensors and dump when you can or on the next trip first thing when checking in.
