nycsteve
Sep 15, 2015Explorer
kohldad wrote:
Guess the valves are on the side and the cables go toward the rear making a 90* turn near the valve. I think I would ditch the cables and put a rod in it's place. To make the 90* transition, just use a triangle plate to redirect the motion.
If the bottom panel is removable as should be to reach the valve itself, would be easy to do the work.
I think you would have another angle at the valve itself, I don't think it faces the right way to just pull.
44,056 PostsLatest Activity: May 04, 2014
