fallsrider's avatar
fallsrider
Dump Valve Replacement
On our '95 Sunnybrook, the black water dump valve is leaking. I use the GEO method, and when I remove the cap, a cup or two of blue water runs out. I know this is coming from the black tank because the Calgon and laundry detergent are blue. So far, the cap has not leaked.
I'm thinking that in the spring when I dewinterize, I need to replace the valve, or at least the seals. What is the proper thing to do there?
Are these seals standard? If so, where is the best place to get them? And since the drain part comes off both the black and gray valves, I should replace them both while I'm in there.
Thanks for your help.
  • I replaced mine just make sure the tanks empty. I bought the replacement from Menards for $10. All that there is to it is the 4 bolts one at each corner of the valve.
