blt2ski
Apr 03, 2015Moderator
mr61impala wrote:BurbMan wrote:
I believe that an 08 will have the newer 6L90E six speed transmission behind the DMax. Yes the DMax is detuned vs the truck versions with the Allison transmission.
Pretty sure the 6L90E wasn't available in the Express until the 2010 model year.
I would prefer the 4L85E anyway, TCM not cooking inside the oil pan.
If the 6l90e is as bad as the th400/4l80/80e versions that I had to replace, rebuild at 30K intervals......not sure I would want that trans vs the others. That included 5K drop the pan and replace filter, and 10K pull trans oil from a jug into the TC while the motor tranny was running on a stand!
The only auto trans I have had behind a BB or TD that lasted over 30K miles is an allison in GM's any how. The 6l90 looks to be a better trans than the th400 derivatives. This is pulling day in and out mind you at 3-4K a month doing my landscape work. I also have had one 700r4 go over 150K also. but it did not get towing duty, just moving an astro van around.......
marty
