Tom_M1
Mar 25, 2014Explorer
As stated before, you h\ave to select the proper input on your TV. This may be called 'Video' or 'AV'. If this does not work make sure the video cable is connected. According to the manual, this model player only has composite video out. This most likely is a cable with a yellow RCA connector. Make sure it's plugged in at the player and your TV.
Edit: You responded before I got my message sent. It may be a bad cable or bad player. It could also be a setting on the player.
If you don't have the manual, here's a link to download it: Manual
44,029 PostsLatest Activity: Feb 18, 2021
