iggyAZ
Aug 29, 2018Explorer
AC Thermostat Reset
Well I just found out that you can reset the the t-stat, which resets the computer board in the ac unit.
Turn the tstat off
Once off push and hold the mode and + at the same time for approx 4/5 seconds
and - - (dash dash) will appear.
That will reset everything.
Then you can turn it back on.
Problem I was having was the furnace was not turning on but if you turned it off and then back on it would work fine.
I think this solved my issue.
Turn the tstat off
44,070 PostsLatest Activity: Sep 18, 2026
