AnEv942 wrote:
SidecarFlip wrote:
Aren't the latches adjustable for cam over tension?
Yes, which I've had to readjust. Mainly its the front latch, handle hits converter wont swing down enough so that latch hoop goes into catch. Both hoop of latches and bottom of step leg trying to fit between the catch and wood block at same time.
Just need to move both the catches and wood block away from converter and increase the space between them and each other. Details
Part of the issue is one end of step is attached to slide the other to fixed floor- on the truck/ground twist or in the drive stuff never quite the same. Probably tonight when we stop it'll likey be the back hoop that hitting. Dime against a dollar when we get home -offload on the cement it'll all work like set up...
Great step Mod.
Could you move the wood block to the left side and the latches to the right under the step? that may work better and you won't have to wedge your hand in between the converter and the step support (Just a thought)
