- BruinzfanExplorerThank you everyone for your responses! I tried all of your suggestions but no luck. I just called the small dealer that has worked on my trailer. The owner is always available to help. The converter is in the front coat closet and the DC wires (and AC) go directly into the floor. I have a battery disconnect in the medicine cabinet. The wires are not visible and I didn't put 2 & 2 together, just assumed it just a disconnect for the Bat. But it's in that box. So the suggestion for the bathroom was correct but I didn't look past my nose. Thank you again!
Keith - tvman44ExplorerOur SunnyBrook fuses are high up in the back of the bathroom closet also, directly above the converter location and toilet inside that cabinet in a black box.
- CrabbypattyExplorerYeah took me a while to find them also. In my Sunnybrook they are located in the ceiling cabinet next tot he microwave in the kitchen. Weird place I had to locate it after I blew a fuse. I since went out and bought the fuses need to replace them and taped them inside the door.
- valhalla360Navigator
kaydeejay wrote:
My Sunny fuses are high up in the back of the bathroom closet, directly above the converter location.
Otherwise, follow the thick wires from the converter as best you can.
Good luck.
That's where they are in ours. - kaydeejayExplorerMy Sunny fuses are high up in the back of the bathroom closet, directly above the converter location.
Good luck. - Old-BiscuitExplorer IIITypically the DC Fuses in trailers are with the AC Panel and converter
BUT sometimes mfg. like hiding them by using a fuse block.
Could be in an overhead cabinet above kitchen sink, sofa, TV Shelf or toilet.
It's like a scavenger hunt.....good luck!
