bgradert
May 12, 2016Explorer
fla-gypsy wrote:
I'm confused why it would come off if it is indeed hooked? FYI, I use the trailer jack to raise mine high enough to remove all tension when hooking up which may eliminate this issue for you as well.
There are two grooves in the "hook" that your chain attaches too. Once I apply pressure to the chain, the chain wants to slip off the "hook".
