hohenwald48
May 12, 2016Explorer
bgradert wrote:fla-gypsy wrote:
I'm confused why it would come off if it is indeed hooked? FYI, I use the trailer jack to raise mine high enough to remove all tension when hooking up which may eliminate this issue for you as well.
There are two grooves in the "hook" that your chain attaches too. Once I apply pressure to the chain, the chain wants to slip off the "hook".
You need to raise it higher using the tongue jack.
