hohenwald48
May 12, 2016Explorer
"I felt like I went up pretty high with it last time I tried hooking it up. I can try to raise it higher if that is what it takes."
I've heard of folks who claim they have to raise it so much the rear wheels of the TV come off the ground.
hohenwald48 wrote:bgradert wrote:fla-gypsy wrote:
I'm confused why it would come off if it is indeed hooked? FYI, I use the trailer jack to raise mine high enough to remove all tension when hooking up which may eliminate this issue for you as well.
There are two grooves in the "hook" that your chain attaches too. Once I apply pressure to the chain, the chain wants to slip off the "hook".
You need to raise it higher using the tongue jack.
