dthfsa wrote:
Appears to be the Kitchen area ceiling lights and the over the island lights. I tried every thing else and it all worked. Along with the both AC units. The frig was one.
When I disconnect the battery and plug into shore power it appears I no power to the 12 volt side. I think I only get power from the battery.
This does not explain the bad circuit yet.
this doesn't sound right / good. It appears to be a problem with the converter somewhere or you still have a fuse issue. Most converters have a point where you can readily measure the voltage being produced so you DO need a meter to check this. Of course, also indicating specifically what converter you actually have will help narrow down the issue further.
