Lemonhead78 wrote:
Huntindog wrote:
The most common cause is a bad connection at the plug. Where are you plugging it in? Do you plug in at home, or only at campgrounds?
The receptacles can wear out, and become a loose fit, which leads to heat and or arcing... The evidence is what you are seeing on your plug.... Also, adaptors are notorious for causing these problems. A lot of people skimp on the adaptor... Big mistake.
I plug in at both. Only at home firb2!days before we leave for the fridge to get going . I USe an adapter so I can plug into wall. The problem is definitely at the campground. There's no adapter I should be using when plugging into campground correct ?
Most likely you are doing it at home when you plug into the oulet with the adaptors.
