Lemonhead78 wrote:
So.... if you guys were to take a guess. Is it my trailer causing this to happen ? I thought the breaker would just trip if too much draw. I do run everything on electric. Fridge , hot water , and air conditioner. I thought it's meant to be able to handle all that. In your guys opinion is it the camper or campground receptor.?
If you are running the A/C or a space heater near continuous I always recommend setting water and fridge to propane only so to avoid the headache of a burned cord end.
But generally I believe most crimped and moulded RV plugs are marginal at best. So if you run them at max rating at your own peril. I listed a premium replacement plug above.
