wrvond
Feb 09, 2016Explorer II
You need to know how those disc brakes are actuated and if that is compatible with your controller.
Simple disc brakes are often used on relatively light trailers (such as boat trailers). These brakes are strictly surge actuated hydraulic brakes. Their weakness is the inherent delay between the time the tow vehicle starts slowing and the trailer presses forward against the coupler to pressurize the hydraulic system. No brake controller needed.
More common on campers is the electric over hydraulic system. Many brake controllers are not compatible with this system. When you step on the brake an electrical signal activates a motor mounted on the camper which pumps up the hydraulic system. Again, there is an unavoidable delay in the system, though some better systems go a long way to minimize that. Personally this system has always struck me as rather a Rube Goldberg type device and rather inelegant.
Finally, the electric drums. By far the most common system. It uses electromagnets to actuate the brake shoes inside the brake drums. Brake drums do not dissipate heat particularly well, are subject to greater wear than disc, and because the shoes are out of sight are often neglected to the point they no longer function. Properly adjusted and maintained they are sufficient for the vast majority of braking needs.
44,071 PostsLatest Activity: Aug 23, 2026
