westend
Feb 10, 2016Explorer
HappyPhantom wrote:Don't worry. Keep searching and reading on this Forum. Nearly every situation and topic has been covered at some point. If you have a good dealer, that can be a good source of help, also. RV's are complex but the basic towing aspects have been the same for years. FWIW, my 1971 TT and truck, equipped with a Prodigy 2 brake controller stops everything seamlessly.westend wrote:HappyPhantom wrote:
Thanks for all of the info - after the comments about KZ even offering disc brakes, I did a little further research, and it appears that KZ uses what they call "auto-adjusting brakes," which are electric right? I saw the info about the KZ using disc brakes from a third-party website - my mistake for trusting what I read on the internet that didn't come directly from the manufacturer - lesson learned.
Correct, auto-adjusting are electric. The option of disc brakes would be one of the last items on my shopping list. Having dual axles with two sets of brakes on each side, considering the weights involved, are more than adequate. Every semi-trailer is equipped similarly, the drums and shoes being twice the size but weight involved being a factor of 10 X.
Thanks for your explanation. As you can imagine, as a soon to be first-time trailer owner, there is so much to learn, it's a bit overwhelming.
