We did not have a problem with the electric plugs in our trailer getting warm but with all the cool weather we had down in Florida several years ago we needed a way to run our electric heater without going through the trailers electrical system. I put in a waterproof outside receptical and an inside outlet in the side of our slide out. Now we can run the electric heater or other higher usage items like toaster or frying pan without worrying about tripping the trailers breaker when we turn on the water heater or air conditioner at the same time.
Works great!
The device that I used was
this one from West Marine.
Barney
Quite a simple mod.
1. I first determined where the studs were by tapping around on the outside. Then drilled a 2" hole ( I think that was the size) through the outside wall.
2.Cut an opening in the inside wall about 6 inches to the side of the outside hole for the inside plug outlet and box.
3.Snaked a 12/2 wire from outside over to inside hole.
4.Connected outside receptical to wire and mounted it on wall.
5.Connected inside receptical to wire and mounted it on the wall.
6.Checked wiring job with outlet checker - everything showed ok.
7.Plugged in the heater and it worked fine! :)
We have been using a
Vornado electric heater for the past several years. It circulates the heat very well with a large, quiet fan, and has a thermostat and adjustable heat output. We have been very pleased with its' performance during temps down to as low as the high 30's in our 30ft trailer. You can barely hear the fan running when it is on high position.
Barney
