jwicker
Jul 29, 2013Explorer
I stopped by the storage facility with intentions of recording the noise....
But the battery was nearly dead.
I was in my other truck without a 7 way plug, so I just pulled the battery.
I'll have it tested after work.
The jack only has 1 wire connection. The ground is made when the unit is bolted to the A-frame. The star washers are supposed to help maintain a good ground connection. The paint was already gone from that area, so I assumed a good connection would be made.
We'll see what the battery test says.
The unit does not have a drop foot on it. The base plate screws to the center of the bottom of the shaft.
Here is the model I have:
94-0115 BARKER VIP POWER JACK 3500 LB CAPACITY - 18IN STROKE
Manufacturer #: 30828
http://www.pplmotorhomes.com/parts/rv-jacks/VIP-barker-jack.htm
http://www.barkermfg.com/vipjacks.html
thanks
jw
thanks
jw
44,056 PostsLatest Activity: May 04, 2014
