kendive
Aug 02, 2013Explorer
Mr.Beebo wrote:
If your electric jack should fail, most still have a manual means of operation. There should be a rubber cap or tab at the top you can remove to access the cranking nut. It will sound like the national alert siren and you'll have every camper within 100" eyeballing you, but it will suffice in an emergency.
Not if the electric motor is seized up...
My LSI Electric Jack failed and you could not move it at all. I replaced it with a manual one and then was going to repair the Electric Jack. I removed all the gears and motor. Found the motor was bad. Talked to LSI and they don't sell just the motor.
44,056 PostsLatest Activity: May 04, 2014
