Oldtymeflyr
Jul 22, 2016Explorer
Thanks for the comments.
Outboard motors just do not produce that much surplus electrical energy. Our 30hp Honda has a total of 10 amps. We may run it for half an hour a day fishing and that's it. If it was EFI a lot of that 10 amps would go to the EFI system. I don't troll with the 30 hp because it will make oil. With a load it works just fine.
I am going to look at the RC charger a little closer and see if it that will do the trick. I like this because it may be the simplest in the end, just one more not two more batteries.
I will also consider a couple of smaller 12v batteries, one on the solar charger and using one. Our batteries in the camper are generally fully charged in an one to two hours, so there is usually plenty of time for charging the second trolling motor battery.
Thanks, I will follow up with a report, probably in October at the latest.
Rick
Rick
